Create a E+ output variable with the sum of all Cooling coil rates
I am running DOE large office reference building model in EnergyPlus, and I would like to create Monthly Cooling Maximum reports, which would include results of the sum of all cases of one type of variable.
For example: HVAC,Average,Cooling Coil Sensible Cooling Rate [W] HVAC,Average,Zone Air Terminal Sensible Heating Rate [W]
These variables are not included in the meter list (mtd) of the model.
How can I report these and other variables, sum all of them the facility level and then create outputs of the variable?
