Hi,
I want to setup an EMS program where i can change the maximum capacity of the chiller.
For example:
I have chiller 1 (water condensed) and chiller 2 (air condensed). both have a maximum capacity of 1 MW, but i want chiller 1 to follow the heating loads of the building.
If i have heating loads of 0,5 MW and cooling loads of 1 MW i want chiller 1 to work until 0,5 MW and chiller 2 also at 0,5 MW.
If i have heating loads of 1,5 MW and cooling loads of 1,2 MW i want chiller 1 to work until 1 MW and chiller 2 until 0,2 MW.
If i have heating loads of 0,3 MW and cooling loads of 1,2 MW, chiller 1 will work until 0,3 MW and chiller 2 at 0,9 MW, and so on.
Wich actuator i could use to do that?
I'm trying to use EnergyManagementSystem:InternalVariable Available,CHILLER 1,Chiller Nominal Capacity,[W]. For the heating loads i'm using a load profile so i'm trying to match the chiller capacity with the hourly heating load profile.
Thanks for your help
Joao Rosa
