I'm running PAT and am trying to include the OpenStudio Reporting measure. However, every run will fail as soon as I assign the reporting measure. Without it, everything runs fine.
I think (but I'm not exactly sure) that I didn't have this problem a few days ago. A new version of the OpenStudio Results reporting measure came out 1-2 days ago. Not sure is that is related?
The failure gives no output at all. Status is Completed Fail, without listing any warnings or errors. The log files are likewise empty. Further debugging is impossible (or at least, I don't know how), since no results are generated with the reporting measure, as that is actually what seems to be causing the problem.
Any help would be much appreciated. Thank you in advance.
Update 1: the final OSW for one of the failed runs:
"completed_at" : "20200624T113041Z",
"completed_status" : "Fail",
"created_at" : "2020-06-24 19:30:28 +0800",
"current_step" : 0,
"description" : "Autogenerated 0",
"file_format_version" : "0.0.1",
"file_paths" :
"C:/Data/small_hotel/temp_data/analysis_2ee9883c-1dd6-4400-b53d-d3856b3f8c6d/data_point_491e53af-ef07-4421-b8a0-af722af2af46/generated_files",
"../weather",
"../seeds",
"../seed",
"./files",
"./weather",
"../../files",
"../../weather",
"hash" : "4E37D3B4",
"measure_paths" :
"../measures"
"name" : "Alternative 1",
"osa_id" : "2ee9883c-1dd6-4400-b53d-d3856b3f8c6d",
"osd_id" : "491e53af-ef07-4421-b8a0-af722af2af46",
"run_directory" : "./run",
"seed_file" : "small_hotel.osm",
"started_at" : "20200624T113031Z",
"steps" :
"arguments" :
"air_loops_detail_section" : true,
"annual_overview_section" : true,
"building_summary_section" : true,
"cost_summary_section" : true,
"envelope_section_section" : true,
"exterior_light_section" : true,
"hvac_load_profile" : true,
"interior_lighting_section" : true,
"measure_warning_section" : true,
"monthly_overview_section" : true,
"outdoor_air_section" : true,
"plant_loops_detail_section" : true,
"plug_loads_section" : true,
"reg_monthly_details" : false,
"schedules_overview_section" : true,
"source_energy_section" : true,
"space_type_breakdown_section" : true,
"space_type_details_section" : true,
"units" : "IP",
"utility_bills_rates_section" : true,
"water_use_section" : true,
"zone_condition_section" : true,
"zone_equipment_detail_section" : true,
"zone_summary_section" : true
"description" : "Option 1 Description: This measure creates high level tables and charts pulling both from model inputs and EnergyPlus results. It has building level information as well as detail on space types, thermal zones, HVAC systems, envelope characteristics, and economics. Click the heading above a chart to view a table of the chart data.",
"measure_dir_name" : "eff4e7ba-120b-4942-af85-91ee98cefc1d",
"name" : "Option 1 Name"
"updated_at" : "20200624T113041Z",
"weather_file" : "NLD_Amsterdam.062400_IWEC.epw"
No warnings or errors...
Update 2: Running the model in OpenStudio (v1.0.0), using only the OpenStudio reporting measure fails (for message see comment below). The run.log file shows the following trace:
[09:45:59.636175 ERROR] undefined method measure_warning_section' for OsLib_Reporting:Module
C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:ineval'
C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:in eval'
C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:inblock in arguments'
C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:140:in each'
C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:140:inarguments'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:368:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:92:inblock in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_preprocess.rb:73:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:973:inexecute'
:/openstudio_cli.rb:763:in execute'
:/openstudio_cli.rb:1757:in<main>'
eval:149:in eval'
eval:149:inrequire_embedded_absolute'
eval:123:in block in require'
eval:117:ineach'
eval:117:in require'
eval:3:in<main>'
[09:45:59.636249 ERROR] :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Error assigning argument in measure :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb. Failed with undefined method measure_warning_section' for OsLib_Reporting:Module, C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:ineval'
eval:149:in eval'
eval:117:ineach'
eval:3:in<main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:472:in rescue in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:353:inapply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:92:in block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_preprocess.rb:73:inperform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'
:/openstudio_cli.rb:973:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1757:in <main>'
eval:149:ineval'
eval:149:in require_embedded_absolute'
eval:123:inblock in require'
eval:117:in each'
eval:117:inrequire'
eval:3:in <main>'
[09:45:59.636443 ERROR] Found error in state 'preprocess' with message [":/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Error assigning argument in measure :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb. Failed with undefined methodmeasure_warning_section' for OsLib_Reporting:Module, C:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:in eval'\nC:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:ineval'\nC:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:143:in block in arguments'\nC:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:140:ineach'\nC:/Users/PAULBO~1/AppData/Local/Temp/osmodel-1593049438-1/resources/measures/OpenStudioResults/measure.rb:140:in arguments'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:368:inapply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:92:in block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_preprocess.rb:73:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:ineval'\neval:149:in require_embedded_absolute'\neval:123:inblock in require'\neval:117:in each'\neval:117:inrequire'\neval:3:in <main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:472:inrescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:353:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:92:inblock in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_preprocess.rb:73:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:647:in rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:305:inapply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:92:in block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_preprocess.rb:73:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:ineval'\neval:149:in require_embedded_absolute'\neval:123:inblock in require'\neval:117:in each'\neval:117:inrequire'\neval:3:in `<main>'"]}
