Zero cooling electricity in Energy+
i'm trying to calibrate a building model using jEPlus. i've modeled the building in DesignBuilder and used a "Cooling System: Default" with "Cooling system seasonal CoP: 2.1" for its cooling system but i can not find where the COP is defined in the .idf file. also when running the project in the jEPlus the "End Uses" table in .csv file show zero for cooling electricity. however the "District Cooling" has a value and if divide it by CoP=2.1 it would be exactly the value which DesignBuilder reports for "Cooling (Electricity)". i need to define a parameter for CoP in jEPlus so i can calibrate it. thank you in advance!
