I had some issue removing a subsurface via the sketchup plugin as it led to the model failing when run. I opened the text file and removed the subsurface that way but when i then save this it obviously saves as a text file and then i dont know how to save it as an osm file so i have the updated model with the errors that led to failure removed. Does anyone know how to fix this?
