Having trouble importing GBXML from Sketchup and OpenStudio into other modeling tools. I get a load error in HAP5.11 and no import at all in Trace 700. Attached is the HAP5.11 error.C:\fakepath\SSNE041.tmp.jpg
I tried reinstalling all software and exporting to a new model without success. The export appears to "crunch the numbers" but no file is generated. Oddly, I also noticed that the "Space Type Report" fails to create a file. Not sure if this is the issue, but there are "_" appearing before/after the file name in the save as dialog window and no file name extension option is shown : C:\fakepath\save as window.png
I'm using:
- Windows 10
- OpenStudioApplication-1.0.0.4f5416cfc7-Windows
- SketchUp plugin v1.0.0
- SketchUp Pro 2019.3
I tested the GBXML files and here is the output:
2020-06-17 15:04:43,857 [15] INFO DOEgbXML.XMLParser - START: BUILDING AREA TEST
2020-06-17 15:04:43,889 [15] INFO DOEgbXML.XMLParser - PROGRAMMER'S NOTE: Converted the test file building area units.
2020-06-17 15:04:43,889 [15] INFO DOEgbXML.XMLParser - Standard Building Area: 12486.13608372
2020-06-17 15:04:43,889 [15] INFO DOEgbXML.XMLParser - Test Building Area: 1268.50753138475
2020-06-17 15:04:43,889 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: The test file's Building Area is not within the allowable tolerance of 0.05.
2020-06-17 15:04:43,889 [15] INFO DOEgbXML.XMLParser - END: BUILDING AREA TEST
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - START: BUILDING SPACE COUNT TEST
2020-06-17 15:04:43,904 [15] DEBUG DOEgbXML.XMLParser - There are 4 Spaces in the standard file
2020-06-17 15:04:43,904 [15] DEBUG DOEgbXML.XMLParser - There are 1 Spaces in the uploaded test file
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: The test file's Space Count is not within the allowable tolerance of 0 The difference between the standard and test file is 3
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - END: BUILDING SPACE COUNT TEST
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - START: Building Storey Count Test
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: The test file's Building Storey Count does not match the standard file's .
2020-06-17 15:04:43,904 [15] INFO DOEgbXML.XMLParser - END: Building Storey Count Test
2020-06-17 15:04:43,951 [15] INFO DOEgbXML.XMLParser - START: UNIQUE SPACE ID TEST
2020-06-17 15:04:43,951 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: The standard file has found a duplicate space ID.
2020-06-17 15:04:43,951 [15] INFO DOEgbXML.XMLParser - END: UNIQUE SPACE ID TEST
2020-06-17 15:04:43,967 [15] INFO DOEgbXML.XMLParser - START: SPACE AREAS TEST
2020-06-17 15:04:43,967 [15] INFO DOEgbXML.XMLParser - SPACE ID: Space_0_0
2020-06-17 15:04:43,967 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: Space_0_0 Could not be matched
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - Test File and Standard File space names could not be matched. SpaceId: Space_0_0 could not be found in the test file.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - END: SPACE AREAS TEST
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - START: SPACE VOLUMES TEST
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - SPACE ID:Space_0_0
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: Space_0_0. Failure to find a volume match.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - PROGRAMMER's NOTE: Test File and Standard File space names could not be matched. SpaceId: Space_0_0 could not be found in the test file.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - SPACE ID:Space_1_0
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: Space_1_0. Failure to find a volume match.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - PROGRAMMER's NOTE: Test File and Standard File space names could not be matched. SpaceId: Space_1_0 could not be found in the test file.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - SPACE ID:Space_2_0
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: Space_2_0. Failure to find a volume match.
2020-06-17 15:04:43,982 [15] INFO DOEgbXML.XMLParser - PROGRAMMER's NOTE: Test File and Standard File space names could not be matched. SpaceId: Space_2_0 could not be found in the test file.
2020-06-17 15:04:43,998 [15] INFO DOEgbXML.XMLParser - SPACE ID:Space_3_0
2020-06-17 15:04:43,998 [15] INFO DOEgbXML.XMLParser - TEST FILE FAILURE: Space_3_0. Failure to find a volume match.
2020-06-17 15:04:43,998 [15] INFO DOEgbXML.XMLParser - PROGRAMMER's NOTE: Test File and Standard File space names could not be matched. SpaceId: Space_3_0 could not be found in the test file.
2020-06-17 15:04:43,998 [15] INFO DOEgbXML.XMLParser - END: SPACE VOLUMES TESTmatch.
