Energyplus terminates and in the ERR file, all it says is * Severe * Bad Allocation. I know this is related to the Illuminance Map because if I take it out or make the map very small, the simulation completes. I want the illuminance map to fill the entire space (to get data from all orientations), but I get this error whenever the map crosses interior walls (all in the same zone).
! =========== ALL OBJECTS IN CLASS: Illuminance Map ================
Output:IlluminanceMap, Illuminance Map 1, !- Name living_unit1, !- Zone Name 3.352, !- Z height {m} 1.465, !- X Minimum Coordinate {m} 9.085, !- X Maximum Coordinate {m} 3, !- Number of X Grid Points 0.1, !- Y Minimum Coordinate {m} 3.048, !- Y Maximum Coordinate {m} 10; !- Number of Y Grid Points
I am running E+ with EP-launch. The construction is a modification of the prototype residential house. I have inserted BSDF data (exported from LBNL WINDOW 7.7) for complex glazing systems. This IDF of the prototype house does not import well into Sketchup/OpenStudio (HVAC data doesn't import)...therefore I'm just running E+.
Can someone help with this? I have many sims that need to be done. I would really like to get the illuminance data. Unmethours won't let me upload an image, even when logged in.
