Hi all,
I am going to run co-simulation between Radiance and Eplus as an input to create a schedule for CFS construction and lights schedule in Eplus. In that case I need to use the same weather file for both programs. In Eplus we can change the timestep and the program will adjust the weather, which will I need for Radiance simulation, it has to be the same timestep.
Is there any way I can obtain the same data ? for example 10 minutes time step or 5 minutes ?
Thanks in advance for reading my question.
Best regards,
Adisaputro
