Here is what I have so far:
Make a choice argument with all the refrigeration cases in the model
ref_case = OpenStudio::Ruleset::makeChoiceArgumentOfWorkspaceObjects("ref_case","OS_Refrigeration_Case".to_IddObjectType,model,true) ref_case.setDisplayName("Apply the measure to") args << ref_case
I would like to also have the option of "All refrigeration cases". I have seen many examples that use the following method:
add building to string vector with space type
building = model.getBuilding space_type_handles << building.handle.to_s space_type_display_names << "Entire Building"
However, I would like to maintain the 'makeChoiceArgumentOfWorkspaceObjects("ref_case","OS_Refrigeration_Case".to_IddObjectType,model,true)'
In staying with this approach, how would I add an option for "All Refrigeration Cases"?
