I simulated with adiabatic wall vs constructions with very very low thermal transmittance. I got more realistic results with second option construction. What´s the e+ way to create zero heat flux boundary conditions? thanks
| 1 | initial version |
I simulated with adiabatic wall vs constructions with very very low thermal transmittance. transmittance for a single zone example. I got more realistic results with second option construction.
What´s the e+ way to create zero heat flux boundary conditions? conditions for exterior surfaces? thanks
I simulated with adiabatic wall vs constructions with very very low thermal transmittance for a single zone example. I got more realistic results with second option construction. What´s the e+ way to create zero heat flux boundary conditions for exterior surfaces? thanks
| 5 | retagged |
| 6 | retagged |
