Hi all, Im Using EMS in Energy plus for making my Pump ON while my PV system production is higher then 3000 watts. Here is my Program:
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:SENSOR ===========
EnergyManagementSystem:Sensor, PV_Generation, !- Name Average, !- Output:Variable or Output:Meter Index Key Name Electric Load Center Produced Electric Power; !- Output:Variable or Output:Meter Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
EnergyManagementSystem:Actuator, CHW_Loop_Sch_Modified, !- Name CHW_Loop_Schd, !- Actuated Component Unique Name Schedule:Compact, !- Actuated Component Type Schedule Value; !- Actuated Component Control Type
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAMCALLINGMANAGER ===========
EnergyManagementSystem:ProgramCallingManager, CHW_Program, !- Name BeginTimestepBeforePredictor, !- EnergyPlus Model Calling Point System_Storage; !- Program Name 1
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAM ===========
EnergyManagementSystem:Program, System_Storage, !- Name IF (PV_Generation > 3000), !- Program Line 1 SET CHW_Loop_Sch_Modified = 1, !- Program Line 2 ELSE, !- A4 SET CHW_Loop_Sch_Modified = 0, !- A5 ENDIF; !- A6
I got this Error:
Severe * Invalid Output:Variable or Output:Meter Index Key Name =AVERAGE * ~~~ * For Output:Variable or Output:Meter = ELECTRIC LOAD CENTER PRODUCED ELECTRIC POWER * ~~~ * Entered in EnergyManagementSystem:Sensor=PV_GENERATION * ~~~ ** Unique Key Name not found.
Please can someone guide me? Please note: -HVAC,Average,Electric Load Center Produced Electric Power [W] is taken from my RDD File. -CHW_Loop_Schd is my pump schedule. Thank you
