The problem is i chose a example file from energyplus "example files" folder and modify it on sketchup with euclid and when i run that modify idf file it doesnot produce any output(only produce err and RVAUDIT file only ) although i doesnot change any output variable i only change geometry(add windows and other item littlebit) whereas the example file which is modify produce all result before modification. i tried to read RVAUDIT file it said "requested eso file doesnot found" files content of both modified and unmodified shared below ...kindly help me in this problem
content of RVAUDIT file of modified idf "Thu 05/21/2020 0:47:49.17 ReadVars ReadVarsESO Requested ESO file=eplusout.eso does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated. ReadVarsESO processing:test.mvi Requested ESO file=eplusout.mtr does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated.
" Content of err file of modified idf "Program Version,EnergyPlus, Version 9.3.0-baff08990c, YMD=2020.05.21 00:47, * Severe * <root>[FenestrationSurface:Detailed][WL-1] - Missing required property 'vertex_3_y_coordinate'. * Severe * <root>[FenestrationSurface:Detailed][WL-1] - Missing required property 'vertex_3_z_coordinate'. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=2 ..... Last severe error=<root>[FenestrationSurface:Detailed][WL-1] - Missing required property 'vertex_3_z_coordinate'. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.51sec " Content of RVAUDIT file of unmodified idf "Thu 05/21/2020 0:41:58.81 ReadVars ReadVarsESO getting all vars from:eplusout.eso number variables requested for output= 218 ReadVars Run Time=00hr 00min 0.20sec ReadVarsESO program completed successfully. ReadVarsESO processing:test.mvi Requested ESO file=eplusout.mtr does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated.
