Hi All, I have a chilled water Loop consists of Chiller, pump and adiabatic pipes. Can I make the chiller OFF and let the pump working (ON)? When I use the SYSTEM AVAILABILITY MANAGER, all the loop will be On or Off! how to specify which equipment from the loop to be ON or OFF? Thank you
