What is "Rated Supply Fan Power Per Volume Flow Rate" it is in the openstudio single speed DX heating and cooling coil object but not described in the input output reference.
| 1 | initial version |
Is it the "Rated Evaporator Fan Power Per Volume Flow Rate"
| 4 | retagged |
