Hello everyone, Hope you are all well and in good health.
I'm wondering how can I change the set-point tolerance in energyplus. I mean by that the minimum or maximum temperature difference between an actual node temperature and the corresponding setpoint before a heating or cooling device would turn on or off.
May you all be safe in those times Thanks
