The content of files are sharing here RVAUDIT file contain "Tue 05/19/2020 17:04:44.24 ReadVars ReadVarsESO Requested ESO file=eplusout.eso does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated. ReadVarsESO processing:test.mvi Requested ESO file=eplusout.mtr does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated. "
while err file contain Program Version,EnergyPlus, Version 9.3.0-baff08990c, YMD=2020.05.19 17:04, * Severe * Line: 437 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 437 Index: 0 - Error parsing "FenestrationSurface:Detailed". Error in following line. * Severe * ~~~ 3.289524617561; !- Vertex 4 Z-coordinate {m}
* Severe * Line: 437 Index: 18 - "3.289524617561" is not a valid Object Type. * Severe * Line: 461 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 461 Index: 0 - Error parsing "FenestrationSurface:Detailed". Error in following line. * Severe * ~~~ 3.256337910845; !- Vertex 4 Z-coordinate {m}
* Severe * Line: 461 Index: 18 - "3.256337910845" is not a valid Object Type. * Severe * Line: 485 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 485 Index: 0 - Error parsing "FenestrationSurface:Detailed". Error in following line. * Severe * ~~~ 3.269901779402; !- Vertex 4 Z-coordinate {m}
* Severe * Line: 485 Index: 18 - "3.269901779402" is not a valid Object Type. * Severe * Line: 509 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 509 Index: 0 - Error parsing "FenestrationSurface:Detailed". Error in following line. * Severe * ~~~ 3.491919344484; !- Vertex 4 Z-coordinate {m}
* Severe * Line: 509 Index: 18 - "3.491919344484" is not a valid Object Type. * Severe * Line: 533 Index: 0 - Object contains more field values than maximum number of IDD fields and is not extensible. * Severe * Line: 533 Index: 0 - Error parsing "FenestrationSurface:Detailed". Error in following line. * Severe * ~~~ 3.346833837073; !- Vertex 4 Z-coordinate {m}
* Severe * Line: 533 Index: 18 - "3.346833837073" is not a valid Object Type. * Severe * <root>[GlobalGeometryRules][GlobalGeometryRules 1][coordinate_system] - "Absolute" - Failed to match against any enum values. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=21 ..... Last severe error=<root>[GlobalGeometryRules][GlobalGeometryRules 1][coordinate_system] - "Absolute" - Failed to match against any enum values. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 21 Severe Errors; Elapsed Time=00hr 00min 0.46sec "
