fluid cooler Curve Issue
Hi,
I started with Systems modelling, and this was the error before I even edit any default values. I have 2 Fluid coolers and both have this caution with multiple curve points showing issues. I am not able to understand the source of the issue. What exactly is "The dependent value"?
CAUTION************************ In curve: FluidCooler-FluidCap-fRng&WB_1 the dependent value is exceeding the limits. Value/Min/Max/First time: 7.000 0.000 3.000 1/ 1/ 1 CURINV: No real root for CURVE: 1 1.353483 0.015932 -0.369414 0.000000 0.000000 0.000000 CURINV: No real root for CURVE: 1 1.353483 0.015932 -0.369414 0.000000 0.000000 0.000000 CURINV: No real root for CURVE: 1 1.353483 0.015932 -0.369414 0.000000 0.000000 0.000000
Thank you.
Tanvi
Hi,
Thank you.
Tanvi
Hi,
I started with Systems modelling, am modelling the Water-side systems, and this was the error before I even edit any default values. I have 2 Fluid coolers and both have this caution with multiple curve points showing issues. I am not able to understand the source of the issue. What exactly is "The dependent value"?
Thank you.
Tanvi
