Hi All, Please, I'm trying to Design a heating/cooling system using ASHP and chiller, I added all objects related (WaterHeater:HeatPump:PumpedCondenser, WaterHeater:Mixed and Coilwaterheating:air to waterHeatPump:Pumped I set all the schedules to be always ON. I got the electricity consumption ( End Uses Cooling Electricity) In cooling but for heating is always 0!! I linked these 2 loops ( chiiler and ASHP) to a fan coil terminal units inside the building, I checked all output values such as heating coil capacity, tank Temp, Pump flow rate,.. everything goes well and the tank temperature goes up and down like the heating system is working properly but the Heating end Uses is always 0. In addition, I run the E+ example files ( ASIHPMixedTankTable.IDF, HeatPumpWaterHeaterStratified.IDF...) I always got the same result (End uses heating Electricity is 0). I noticed in the Plant Loop Demand Report Monthly For Hot Water Loop, "PLANT SUPPLY SIDE COOLING DEMAND RATE" and "PLANT SUPPLY SIDE HEATING DEMAND RATE" both columns have values during heating months. (Plz see Link https://polymtlca0-my.sharepoint.com/:i:/g/personal/serge_wehbe_polymtl_ca/Ef-fYkxOTgtMi5JAj57PvR8BotDKcNfCnDbPgZ5qiPJXrQ?e=d5lvXp Thank you in advance.
