I am using designbuilder for making idf file and using energyplus v 9.3.0 while designbuilder has v 8.9.0 so i use version updater for this purpose the question here is "When i run idf file in EP launch program it doesnot generate any output file other than err , i also try to make set but doesnot work" kindly tell the solution
