Hello!
I'm receiving the error below when trying to build a Asharae 90.1 System 4 HVAC Baseline, in Open Studio, a Packaged Rooftop Heat Pump system:
* Severe * <root>[Coil:Heating:Water][Coil Heating Water 1] - Missing required property 'air_inlet_node_name'. * Severe * <root>[Coil:Heating:Water][Coil Heating Water 1] - Missing required property 'air_outlet_node_name'.
May someone help me? I don't know how to require air inlet/outlet properties.
My system:
C:\fakepath\Packaged Rooftop Heat Pump.PNG
Thank you!!
