Hi everyone, When i use search surface tool in sketchup, for example i search for surface 1, I get a lot of surfaces, named surface 1. but in Open studio there is no problem. each surface has its individual correct name. will this be a problem in our simulation??? In fact the name sketch up gives to a surface is different from the name Open studio assign to that surface.
Thank you in advance
