Energyplus output variables
I want to get two output results using Energyplus; Surface inside face conduction heat transfer rate per area and surface window net heat transfer rate. I need to get equal values for these two outputs monthly, without any shading controls and effects. I didn't include any input for shading devices but I couldn't get equal values. It seems like in first three floors , values are less while other floors, values are almost same. Also, last two floors again the less values. It's a 20 storey building. I want to demonstrate that without any shading effect, the values are same. How can I solve this problem.
Thanks
Thanks
Thanks
