Honeybee cannot find RADIANCE folder on your system. Make sure you have RADIANCE installed on your system. You won't be able to run daylighting studies without RADIANCE. A good place to install RADIANCE is c:\radiance
Honeybee cannot find DAYSIM folder on your system. Make sure you have DAYISM installed on your system. You won't be able to run annual climate-based daylighting studies without DAYSIM. A good place to install DAYSIM is c:\DAYSIM
Honeybee cannot find a compatible LBNL THERM installation on your system. You won't be able to run THERM simulations of heat flow through constructions. Only the following versions of THERM are supported: ['7.5', '7.6'] Download supported versions of THERM from:Hone
