What equation does EnergyPlus use to calculate Surface Outside Face Beam Solar Incident Angle Cosine Value?
The equation used in the EnergyPlus source code for Surface Outside Face Beam Solar Incident Angle Cosine Value calculation does not match other sources for this same value.
Energy Plus: cos⁡(θ_i ) = sin⁡(α)sin⁡(β) + cos⁡(α)cos⁡(β)*cos⁡(γ-γ_s)
Other Sources: cos⁡(θ_i ) = sin⁡(α)cos⁡(β) + cos⁡(α)sin⁡(β)*cos⁡(γ-γ_s)
θ_i=angle of incidence
α=solar altitude
β=surface tilt
γ=wall azimuth
γ_s=solar azimuth
The EnergyPlus Reference manual does not explicitly state this equation. Is there another reference that states how EnergyPlus calculates Surface Outside Face Beam Solar Incident Angle Cosine Value?
α=solar altitude
β=surface tilt
γ=wall azimuth
γ_s=solar azimuth
α=solar altitude
β=surface tilt
γ=wall azimuth
γ_s=solar azimuth
