What's a good reference for reasonable parameters for occupants opening windows? There are two objects from energyplus example files below, and the indoor temperatures are beyond reasonable thermostat setpoints. (Maybe these accurately model user behavior though?...) In the ASHRAE9012016_ApartmentHighRise_Denver.idf example, there is also some EMS present to change thermostat setpoints based on the windows being open, which could explain a lot of errors with those models. Some of the other ASHRAE9012016_insert_building_type_Denver.idf have similar ZoneVentilation:WindandStackOpenArea and EMS objects.
The VentilationSimpleTest.idf has a pretty low indoor setpoint as well, but this object appears to represent a permanent opening rather than an operable window.
ZoneVentilation:WindandStackOpenArea,
G SW Apartment Sliding Door Ventilation, !- Name
G SW Apartment, !- Zone Name
0.1181, !- Opening Area {m2}
Sliding_Doors_Ventilation_Availability_SCH, !- Opening Area Fraction Schedule Name
autocalculate, !- Opening Effectiveness {dimensionless}
180, !- Effective Angle {deg}
15.2393, !- Height Difference {m}
autocalculate, !- Discharge Coefficient for Opening
18.89, !- Minimum Indoor Temperature {C}
, !- Minimum Indoor Temperature Schedule Name
25.56, !- Maximum Indoor Temperature {C}
, !- Maximum Indoor Temperature Schedule Name
-100, !- Delta Temperature {deltaC}
, !- Delta Temperature Schedule Name
15.56, !- Minimum Outdoor Temperature {C}
, !- Minimum Outdoor Temperature Schedule Name
26.67, !- Maximum Outdoor Temperature {C}
, !- Maximum Outdoor Temperature Schedule Name
40; !- Maximum Wind Speed {m/s}
ZONE 3 Ventl 2, !- Name
ZONE 3, !- Zone Name
0.5, !- Opening Area {m2}
Constant, !- Opening Area Fraction Schedule Name
0.2, !- Opening Effectiveness {dimensionless}
0.0, !- Effective Angle {deg}
1.0, !- Height Difference {m}
0.5, !- Discharge Coefficient for Opening
18.0, !- Minimum Indoor Temperature {C}
1.0; !- Delta Temperature {deltaC}
