We are working on a residential project. The sensible heat gain summary report shows zero heat gain through opaque surfaces when a shading device is removed. But with high heat gain removal. If a shading device is added, sensible heat gain addition for opaque surfaces shows positive value. Sensible heat removal is reduced. How do we interpret these results? What does a zero value suggest?
