It seems that this should be simpler.... I would like to model a chilled water cooling loop with a fluid cooler and chiller. The fluid cooler should operate a cold outdoor temps (eg, 3C and below). The air-cooled chiller should operate at higher outdoor temps (eg, > 3C)
Implementing that idea is eluding me after trying many options. It would be handy, for example, to use PlantEquipmentoperation:OutdoorDryBulb, but that is applicable only for condenser loops.
Can someone give a little guidance regarding a workable approach? Thanks very much.
