Hello,
I'm using jePlus2.0 for parametric studies and using LCC as output for minimization.
I'm exploring run one hundred, or even thousand different *.idf (every *.idf are previous generated by Montecarlo approach, in order to combine different occupation scenarios) in jePLUS.
Having a lot of .idf to run in jePLUS2.0, there is any solution to run automatically every .idf, instead of manual configuration of each *.idf?
Is it possible to do that with jePLUS2.0?
Note: the "Parameter Table"(jePLUS2.0) and LLC output are the same for all *.idf files.
Thanks in advance.
Cheers
Rui
