Hello,
In my building, I have a heat recovery system for the ventilation that recovers 75% of the temperature difference between supply air en exhaust air. When the outside temperature is for example 10 degrees and de inside temperature is 20 degrees, de supply air has to be 17.5 degrees. Now i have an airloop with a setpoint manager: follow outdoor temperature and a heat exchanger air to air with effectiveness 75%. Now the supply air is only 15 degrees in my example
Can anybody help me? Thanks
