I'm attempting to model a packaged RTU with hot gas reheat in EnergyPlus and using:
Coil:Cooling:TwoStagewithHumidityController
Coil:Heating:Desuperheater
Manufacturer equipment (so far as I can tell) routinely makes 100% of the condenser heat available to a hot gas reheat coil, but E+ limits the heat recovery to 30% - not enough for humidity control in my case.
Am I missing something? How can I make ALL of the condenser heat available to the hot gas reheat coil?
Thanks!
