I modeled the fenestration with a frame and exported the file to E+ from LBNL windows. I have applied the frame to the Fenestration object in my E+ file. However, in the HTML file, I see only the C-o-G U-value and the frame conductance listed. Does that mean the assembly u value would be the same as LBNL? The assembly U-value is 0.42 Btu-h-ft2. How do I check this? Is there a variable to do so? I have looked at some of the past posts but want to know if this approach is correct or If I am missing anything?
Thanks
