Hi, i am currently trying to run a simulation in BCVTB with E+ and Simulink. However, when i tried to run my E+ idf file in E+, i had an error which says socket.cfg is not found, has to be in same location as idf, despite me having a socket file in the same directory as the idf file. I copied the socket file from one of the example from bcvtb as i did not know where to acquire it. Any help is deeply appreciated.
