I would like to pull out hourly data for multiple meters using the Generate CSV measure. I've been successful for individual models in OpenStudio, but when trying to apply it to a larger scale of multiple models in PAT I am not seeing any results populate in the "Generate_CSV" measure folder where they typically are for OS folders. Do the eplusmtr.csv files populate somewhere different in the PAT folder structure or is there a different method for reporting hourly meters that I should use in PAT?
