I just downloaded EnergyPlusV9.3 and started the launcher. I found the tab "Utilities: is blank. Have you had the same pronblem? The utilities are now in other program of the suite that I dis not notice?
Regards.
STAY SAFE, if you can STAY HOME
| 1 | initial version |
Regards.
I just downloaded EnergyPlusV9.3 and started the launcher. I found the tab "Utilities: is blank. Have you had the same pronblem? problem? The utilities are now in other program of the suite that I dis did not notice?
Regards.
| 3 | retagged |
I just downloaded EnergyPlusV9.3 and started the launcher. I found the tab "Utilities: is blank. Have you had the same problem? The utilities are now in other program of the suite that I did not notice?
Regards.
