In the simulation process, I need to know the hourly load of the building, so I selected two variables of HVAC,Sum,Zone Ideal Loads with Total Heating Energy and HVAC,Sum,Zone Ideal Loads with Total Cooling Energy in the RDD file after operation, and the following error occurred after the second operation.Could you please tell me how to solve this problem?
* Severe * Line: 24350 Index: 0 - Error parsing "Output:Variable". Error in following line. * Severe * ~~~ * Severe * Line: 24350 Index: 10 - "Hourly" is not a valid Object Type. * Severe * Line: 24355 Index: 0 - Error parsing "Output:Variable". Error in following line. * Severe * ~~~ * Severe * Line: 24355 Index: 10 - "Hourly" is not a valid Object Type. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination.
