"Ideal Loads Options" measure question
I'd like to set the minimum supply air temperature in cooling to a specific value for an ideal air loads system. The "Ideal Loads Options" measure says it can set this value in the description, but there doesn't appear to be a field for this in the measure. What am I missing here? I'm using OS v2.7.0
