Hi fellow modelers,
I am working on a compliance energy model for which we are considering the ASHRAE 90.1-2010 Energy Cost Budget (chapter 11) method. Under the budget (baseline) building, section 5 in Table 11.3.1, the instructions refer to the section 5.5.4.5 where the baseline model needs to comply with:
As>=Aw and As>=Ae
As= south oriented vertical fenestration area Aw= west oriented vertical fenestration area Ae= east oriented vertical fenestration area
Our building has As=0. The code says: "If the fenestration area facing west or east of the proposed building exceeds the area limit set in Section 5.5.4.5, the area shall be reduced proportionally until the area is the same as the area limit set in Section 5.5.4.5. The area limit is the fenestration area facing south in the northern hemisphere or the fenestration area facing north in the southern hemisphere as defined in Section 5.5.4.5."
Has anyone dealt with this before? Does this mean that we should assume no windows for east and west sides on this building to comply with this section?
Any thoughts/interpretations would be appreciated.
