Hello all,
I am totally new to this program and this forum. I apologize, I do know how to solve these errors listed below. Any help or guidance towards the right direction would be greatly appreciated!
Program Version,EnergyPlus, Version 9.2.0-921312fa1d, YMD=2020.03.13 10:01,
* Severe * <root>[Coil:Cooling:Water][Fan Coil with Const Fan Var Fluid Flow - Cooling Coil] - Missing required property 'water_inlet_node_name'.
* Severe * <root>[Coil:Cooling:Water][Fan Coil with Const Fan Var Fluid Flow - Cooling Coil] - Missing required property 'water_outlet_node_name'.
* Severe * <root>[Coil:Heating:Water][Coil Heating Water 1] - Missing required property 'water_inlet_node_name'.
* Severe * <root>[Coil:Heating:Water][Coil Heating Water 1] - Missing required property 'water_outlet_node_name'.
* Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=4
..... Last severe error=<root>[Coil:Heating:Water][Coil Heating Water 1] - Missing required property 'water_outlet_node_name'.
*** Warning: Node connection errors not checked - most system input has not been read (see previous warning).
*** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
*** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
*** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 4 Severe Errors; Elapsed Time=00hr 00min 0.40sec
