I'm stuggling to model a chilled beam system in Trane 3D Plus. Even when I select passive chilled beams it throws an error: "AirLoopHVAC RR 2 _Passive Chilled Beams has no air flow".
The room is a restroom but should have airflow right? Other systems with airflow ex. PFP VAV works and produces good results.
