I would like to use the autosizing feature for a boiler and chiller in a building I am testing. I would like to add an oversize factor so the plant equipment is at 110% of the peak load. I do not want to hard-code the numbers as I will be using this model in a range of weather climates using PAT. Is there a way to add or customize an oversize factor in OpenStudio or PAT?
