Is there an easy way to return the condenser water PlantLoop that is associated with a given Chiller PlantLoop?
So far, I can get the chiller ok, but can't seem to directly get the associated condenser plant loop, just the condenser water inlet/outlet nodes.
if not chiller_plant_loop.supplyComponents(OpenStudio::Model::ChillerElectricEIR::iddObjectType).empty?
# Get chiller
chiller = chiller_plant_loop.supplyComponents(OpenStudio::Model::ChillerElectricEIR::iddObjectType).first.to_ChillerElectricEIR.get
if chiller.condenserType == 'WaterCooled'
# Chiller is WaterCooled therefore should be connected to a condenser water loop
# How do I get the associated Condenser PlantLoop?
end
end
If I can avoid getting the inlet or outlet node and looping on ALL condenser water loops to find that node, that'd be much better.
