Hello,
I autosize Low Speed Gross Rated Total Cooling Capacity and High Speed Gross Rated Total Cooling Capacity for two stage DX cooling coil. Low Speed Gross Rated Total Cooling Capacity is 1/3 of High Speed Gross Rated Total Cooling Capacity. Is there any way I can change this ratio such as 35% in EnergyPlus?
Thanks,
Eric
Coil:Cooling:DX:TwoSpeed, BaseSys13 CoilClg, !- Name Always On, !- Availability Schedule Name autosize, !- High Speed Gross Rated Total Cooling Capacity autosize, !- High Speed Rated Sensible Heat Ratio 3.9094111254, !- High Speed Gross Rated Cooling COP autosize, !- High Speed Rated Air Flow Rate , !- Unit Internal Static Air Pressure BaseSys13 OACtrl OA System Mixed Air Node, !- Air Inlet Node Name BaseSys13 CoilClg Outlet Node, !- Air Outlet Node Name CoilClgDXQRatio_fTwbToadbSI, !- Total Cooling Capacity Function of Temperature Curve Name CoilClgDXDblQRatio_fCFMRatio, !- Total Cooling Capacity Function of Flow Fraction Curve Name CoilClgDXEIRRatio_fTwbToadbSI, !- Energy Input Ratio Function of Temperature Curve Name CoilClgDXDblEIRRatio_fCFMRatio, !- Energy Input Ratio Function of Flow Fraction Curve Name CoilClgDXEIRRatio_fQFrac, !- Part Load Fraction Correlation Curve Name autosize, !- Low Speed Gross Rated Total Cooling Capacity autosize, !- Low Speed Gross Rated Sensible Heat Ratio 3.9094111254, !- Low Speed Gross Rated Cooling COP autosize, !- Low Speed Rated Air Flow Rate CoilClgDXQRatio_fTwbToadbSI 1, !- Low Speed Total Cooling Capacity Function of Temperature Curve Name CoilClgDXEIRRatio_fTwbToadbSI 1, !- Low Speed Energy Input Ratio Function of Temperature Curve Name , !- Condenser Air Inlet Node Name AirCooled, !- Condenser Type , !- Minimum Outdoor DryBulb Temperature for Compressor Operation 0.0, !- High Speed Evaporative Condenser Effectiveness autosize, !- High Speed Evaporative Condenser Air Flow Rate autosize, !- High Speed Evaporative Condenser Pump Rated Power Consumption 0.0, !- Low Speed Evaporative Condenser Effectiveness autosize, !- Low Speed Evaporative Condenser Air Flow Rate autosize, !- Low Speed Evaporative Condenser Pump Rated Power Consumption , !- Supply Water Storage Tank Name , !- Condensate Collection Water Storage Tank Name 0.0, !- Basin Heater Capacity 10.0; !- Basin Heater Setpoint Temperature
