Hi there.
I have been attempting to run just a basic test (20 files) of ResStock (v2.2.1). I have followed along with the documentation in trying to get it to run with PAT on AWS. I successfully can get the server script to start up but I keep getting the same error resulting in all my models to fail.
Here is the error log on one models around the first utterance of an error.
It seems as though it is not locating the buildstock.csv, however based on my reading this should trigger a ruby script to generate it? So not sure if it is a bigger problem with the environment not being able to run that? Any ideas are appreciated.
