I'm working on a warehouse model that is going to use dayligth as a ECM and 12% of the roof ceiling is going to be skylight. I would like to know if theres a plugin or an option to model the skylight's pretty much like the "Set Window to Wall Ratio Plugin" or if theres another option instead of doing one by one? as you can see I have a long way to go.
I need to create around 144 skylights due to the curve of the roof ceiling and I always avoid copy anything when it comes to sketch up in my expirience I end up with a lot of errors.
