I am working on my master thesis with energy plus. During my simulation I have used solar collectors and CHP systems, in both cases I have used the templates in the example files SolarCollectorFlatPlateWater.idf and MicroCogeneration.idf in the results of my simulation in SYSTEM NODE TEMPERATURE the Inlet temperature of these component are Higher than Outlet Temperatures Which is also the case in the example files which makes no sense so I am guessing there are some problems with the Coefficients in the Performance Object associated with these objects. If it is, may I have the correct Values?
