model a water to water heat pump (Equation Fit Approach)
How can I model a water to water heat pump between a solar collector and water heater.
Is there any example file from energyplus? In addition of the documentation, as I went through it but is not clear to me the steps.
Note: This model is a special case as usually water to water heat pumps are made to perform with ground source heat exchangers.
click to hide/show revision 3
No.3 Revision
model a Solar PVT with water to water heat pump (Equation Fit Approach)
How can I model a water to water heat pump between a solar collector and water heater.Hi, Thanks your response!
Is there any example file from energyplus? I have exactly done what you suggested. In addition this case I decided to connect the wwhp between the solar collectors and water heater (E_Schematic). The diagram, and the idfile is also attached in this email. However, I am getting an error that I cannot figure out. I do not know why it is requesting me or providing me an error of placing a pump at each plant loop. I am trying to avoid the documentation, as heatExchanger, but if it is required to finish the modelling I went through it but is not clear to me the steps. will do so.
Note: This model is a special case as usually water to water heat pumps are made to perform with ground source heat exchangers.Please, any suggestions?
Solar PVT with model a water to water heat pump (Equation Fit Approach)
Hi, Thanks your response!How can I model a water to water heat pump between a solar collector and water heater.
Is there any example file from energyplus? In addition of the documentation, as I have exactly done what you suggested. In this case I decided went through it but is not clear to connect me the wwhp between the solar collectors and water heater (E_Schematic). The diagram, and the idfile is also attached in this email. However, I am getting an error that I cannot figure out. I do not know why it is requesting me or providing me an error of placing a pump at each plant loop. I am trying to avoid the heatExchanger, but if it is required to finish the modelling I will do so.steps.
Thanks,C:\fakepath\E__Schematic.jpg(/upfiles/1435977716960155.jpg)Note: This model is a special case as usually water to water heat pumps are made to perform with ground source heat exchangers.
Update
I have exactly done what you suggested. In this case I decided to connect the wwhp between the solar collectors and water heater (E_Schematic). The diagram, and the idfile is also attached in this email. However, I am getting an error that I cannot figure out. I do not know why it is requesting me or providing me an error of placing a pump at each plant loop. I am trying to avoid the heatExchanger, but if it is required to finish the modelling I will do so.
Thanks,
C:\fakepath\Solar PVT.jpg
click to hide/show revision 6
No.6 Revision
Update
Thanks,
THIS IS THE DIAGRAM C:\fakepath\Solar PVT assissted by a heatpump.jpg
Update
Thanks,
