My chiller capacity is 133% higher than the OpenStudio design cooling load to meet the zone set point temperature. Why there is a big difference and Why the zone set point temperature is not met at the design cooling load?
I am modelling a existing 12 storey office building. For validation purpose, I conditioned only 10th floor with actual cooling load and internal heat gains. I took water cooled chiller for my simulation. The OpenStudio design cooling load of 10th floor is 63 kW. My actual cooling load is 147 kW. I hard sized the chiller capacity as 147 kW, hence the zone set point temperature was met. If I take OpenStudio design cooling load of 63 kW as my chiller capacity, the zone setpoint temperature was not met. I assumed wall and window material properties with reasonable accuracy.
Please clear my doubts.
