Enable ZoneProperty:UserViewFactors:bySurfaceName
Hello,
I´m working to get the ZoneProperty:UserViewFactors:bySurfaceName to work on a test file.
So far, with the great help from Radiance developers we have found a way to automate the writing of these viewfactors. However, once written, the simulation Succeeds but tje test file keeps throwing the same error severes in eplusout.err as before
Severe
** Problem in interior solar distribution calculation
(CHKBKS)(CHKBKS)
** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=ZONE_6
** ~~~ ** because vertex 1 of back surface=ZONE_6_SRF_8 is in front of receiving surface=ZONE_6_SRF_10
** ~~~ ** (Dot Product indicator=30.6234)
** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
** Severe ** Problem in interior solar distribution calculation (CHKBKS)
** ~~~ ** because vertex 2 of back surface=ZONE_6_SRF_8 is in front of receiving surface=ZONE_6_SRF_10
** ~~~ ** (Dot Product indicator=24.7603)
Is there any specific field in the idf where I need to enable the use of these ZoneProperty:UserViewFactors:bySurfaceName?
The files are here: original model and viewfactor model.
Thanks,
Rafael
