DHW simulation w/ solar panels + diesel boiler
Hello!
I'm trying to model a DHW system with 135 solar panels and a 400kW diesel boiler for backup. Storage tank has 5m3. The objective of this modelling is to audit an existing system.
The objects I used for the simulation are:
  • SolarCollector:FlatPlate:Water to model the solar panels;
  • WaterHeater:Stratified to model the storage tank;
  • DistrictHeating to model the diesel boiler (for simplicity at the beginning)
I started the modelling based on the example file SolarCollectorFlatPlateWater, and changed components to meet my necessities.
However, when running, the following error message appears:
* Severe * InitWaterThermalTank: Detected problem for stratified tank model. Model cannot be applied. * ~~~ * Occurs for stratified tank name = STORAGE TANK * ~~~ * Tank volume = 5.0000 [m3] * ~~~ * Tank use side volume flow rate = 3.8893 [m3/s] * ~~~ * Tank source side volume flow rate = -99999.0000 [m3/s] * ~~~ * Nominal tank change over rate = 1.29 [s] * ~~~ * Change over rate is too fast, increase tank volume, decrease connection flow rates or use mixed tank model
Attached are the printscreens of the main components of the modelling. [C:\fakepath\01.sizing.plant.JPG] (/upfiles/15801279886906408.jpg) (/upfiles/15801279783590061.jpg) (/upfiles/15801279665273053.jpg) (/upfiles/15801279586197834.jpg) (/upfiles/15801279529450353.jpg) (/upfiles/15801279456527095.jpg) (/upfiles/15801279393225686.jpg) (/upfiles/1580127933819217.jpg)
Does anyone has the idea of where the problem could be?
Thanks a lot in advance.
Hello!
Attached are the printscreens of the main components of the modelling. [C:\fakepath\01.sizing.plant.JPG] (/upfiles/15801279886906408.jpg) (/upfiles/15801279783590061.jpg) (/upfiles/15801279665273053.jpg) (/upfiles/15801279586197834.jpg) (/upfiles/15801279529450353.jpg) (/upfiles/15801279456527095.jpg) (/upfiles/15801279393225686.jpg) (/upfiles/1580127933819217.jpg)modelling.
Hello!
Sizing:Plant image description
SolarCollector:FlatPlate:Water image description
DistrictHeating image description
WaterHeater:Stratified image description
PlantLoop image description
PlantEquipmentList image description
WaterUse:Equipment image description
WaterUse:Connections image description
Hello!
