Hello!
A similar question was asked here, but the answers don't really solve my problem. I believe their issue was usage of sub-hourly calculations, which is not applicable in my case.
In my case, I am creating my own inverse facade heat transfer model doctoral research. My current goal is to compute the wind speeds felt by facade surfaces, and know that the computed wind speeds and DOE-2 convection coefficients line up with those output by EnergyPlus. I have simulated a building on EnergyPlus using the Atlanta TMY3 EPW file, and the wind speeds output by "Site Wind Speed" do not line up with those from the EPW file. Because these speeds are not the same, my computation of the wind speeds on my roof surface are off and my convection coefficients are off.
When I take the EnergyPlus Output: Site Wind Speed and run it through my calculation, the calculated surface wind speeds exactly match those output by EnergyPlus. This indicates to me that there is something happening within EnergyPlus that converts the EPW wind speeds to Site Wind Speeds. Any ideas?
Attached are files that may be useful.
